17-03-2017 #231
I had similar issues. Brushes need to be clean and carbon free (And clearly not worn out). I stripped the motor down as far as I could and found that previously someone had put some putty on the wingdings. I Can only assume the motor had basically started to fail and this was a 'plaster' to keep it going.
I would only get around 30% of full current before the motor would stall. It would then overheat and start smoking from the brush area.
I triple checked the setup and verified with the supplier of the drive (they were really good) - KEITH SANSBY <[email protected]> . So clearly the motor was the problem. Symptoms also included 'hunting' around high speed and any loading would make it worse.
20-03-2017 #232
20-03-2017 #233
20-03-2017 #234
20-03-2017 #235
That's certainly a tight fit.
Any idea what size flange is on the motor?
I think a 100mm flange motor would squeeze in, however I couldn't find any with the power I was aiming for, so opted for a 110mm motor, and spacing it up.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
21-03-2017 #236
21-03-2017 #237
05-08-2017 #238
Hi Chaz,
I have just acquired 1/2 of a TRIAC VMC today so will follow your threads with interest. The Miller was going for scrap. Unfortunately I don't have the controller or a schematic but do have the monitor/PC, not that I think it of much use on its own. I have to decide if the miller is worth the time of effort to "upgrade". Even with the latest electronics/controllers its not as simple as plug and play. I agree its heavier than it looks. The C of G is not where you expect it either. The lifting eye on the top gives the game away.
06-08-2017 #239
I noticed your post over on the Denford forum earlier.
Without the control box, there will be a lot more wiring needed done, but there's nothing insurmountable if you really want to get the machine running.
From the photos you posted over on the Denford forum, you've got a BT30 spindle (it's got an 8 position tool changer), and stepper motors.
Ultimately to get it running, you'd need 3 stepper drivers (plus suitable power supply), a spindle drive, some form of controller, and lots of relays.
If you do decide not to keep it, I'd be interested. I've got a BT35 spindle version, but would quite like a BT30 version as toolholders are far easier to get, so I could swap the required bits.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
07-08-2017 #240
Hi Chaz,
Thanks for your quick reply. I obtained a battery powered folk lift truck (FLT) from the same source...with 50% of the battery's shot. I used the FLT to move the miller with the aid of some deep cycle battery's. I need to do a little more reasearch on the cost, time, effort, choice of controllers + do I need a miller....etc before I write it off. My current urgent need is to buy a small metal lathe (Viceroy) off a friend in Magor now that I have 3 Phase on site.. Dare I ask what its worth to you? Can you swap the toolholder easily between machines? Yours for mine? I don't need this functionality and it probably complicates the control electronics. BTW I am near Welshpool. You would need to collect. There is a slim possibility the controller is about in the factory it came from. I need to have a search now I know what I'm looking for.
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
