    Can I double check something, for the 0-10V Analog input, this shows using 1 and 14 for the first axis. On the pic below, the left hand side is the wiring of the drivers.
    Ok well kind of right but your needing ANALOG +/-10V OUTPUTS for the Channel(axis) your using.! . . . It's not 0-10V ANALOG INPUTS they are very different things.!!
    I realise you probably know this but it's these little details and wrong INFO back to us here that can get confusing and you in BIG trouble if we do and your letting out Magic smoke.!
    Vref - = Negative Voltage ie: -5v = right direction at half Motor rpm
    Vref + = Positive Voltage ie: +5v = Left direction at half Motor Rpm
    Manual will show you which pins are for Negatve and Positive for Each Channel(axis). Careful you don't Mixup the GND because the Channel GND's are different to Analog input GND's on same connector.!
  1. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  2. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  3. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  4. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
