20-06-2015 #11
So I need to simply bridge between terminal 14 and 15 of the IRTA Drive. What function do I use on the CS Labs unit? Analog Out? Does this push out a voltage or does it simply close a circuit and work as a softswitch?
If I look at the analog out options, I have Analog output 0 (0-10V on pin 7) and Analog output 1 (0-10V on pin 8). I would have thought I needed to use the digital outputs? Sorry, a little bit confused, just want to 'make' a connection between 2 points.
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
