19-07-2015 #11
Yep, spot on. Mine is about DER timing I feel. As the Denford uses inverse logic, its been a bit more painful as the CS Labs unit cannot provide 'switch on this 0V option' from what I can see. I also dont understand why, when Mach3 goes into 'reset mode' that the machine moves itself in X and Y positive direction. I think disabling the drives will help here, currently the DER relay is kept powered (well, zeroed, 24V is permanent) via hardwiring. Ill swap the logic and then use one of the enable outputs, like what I am doing with the new Kinco drive that replaced a damaged IRT drive.
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM
