    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 19 Hours Ago Has a total post count of 1,654. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by xiteamxi View Post
    any update on your build did you finish the atc conversion?
    Yes, its fully working with Mach3. Id like to redo some of the wiring but its working as needed. Ive since installed an AC Servo spindle as the DC motor wasnt working well.
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 368 times, giving thanks to others 9 times.
    Any details on the servo conversion?
    I've currently got mine in bits, and am currently working on the finer details of how the servo is going to fit.
    Chaz's Avatar
    Ye, Ill share some stuff when I get home. I had to do a fair bit of test fitting due to the constraints of the physical space. I am using a 1.5KW Panasonic servo.
    So you have upgraded the spindle to a Panasonic one? How does it work with atc?
    I'm gagging to upgrade my spindle, I've got money just no options
    Chaz's Avatar
    Quote Originally Posted by andy_con View Post
    Yep. It works well. I dont use my ATC often but functionally it works. I can do some improvements to it for fine tuning but the machine is now running at minimum as good as it would have when new.
    Where are you based? You are welcome to come look at the bits.
    So spindle speed? How have you got it to work?
    What kind of setup?
    The triac has a slightly different atc seti
    Up the. Most with its spindle and powered draw bar
    I'm in Essex?
    Chaz's Avatar
    Direct motor replacement, 4400 rpm due to slight change in gearing.
    Im in West London - UB108TE, feel free to pop around, Im home Saturday if you want to see my mess.
    Ill take some pics anyways to share.
  1. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  2. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  3. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  4. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
