Thread: Metal Working Lathe
17-06-2015 #1
Hello everybody, I live in the UK and I am looking to buy my first Lathe. I have a budget of about £2000 I would need the lathe to be able to produce fairly big work pieces (at least 50cm in length) and work with most metal materials. I am torn between buying an older second hand one which seem to be more rugged, or a newer Chinese based lathe. I'm interested to hear peoples experiences and what they would recommend as a good quality machine.
17-06-2015 #2
Hi Dan
I have a colchester student which generally has a centre height of 6.5 inches and 24 inches between centres (they are labelled as 6" but most are master CH )
It weighs 675kg and has a largeish footprint
You could get one for £1000 ish with 2 chucks steadys etc
leaveing you with £500 to buy tooling and accesories
You will get all that and more back if you ever sell it
Parts are easily available and reasonably priced (unless new)
Pleasure to use it...If you have the room you wont regret it
17-06-2015 #3
Thanks for replying is there a company that sells them? or am I looking for second hand one?
17-06-2015 #4
Definitely second-hand, but there are various dealers around that often list them (try Google!) or they sometimes turn up from private sellers. You will probably need to budget for a three-phase inverter if it's from a dealer as it will have come from a commercial workshop. Not a bad way to go, though.
17-06-2015 #5
That's a good idea I will keep a look out is there any makes you would highly recommend other than the Colchester?
17-06-2015 #6
The british makes you should look out for on ebay perhaps are colchester harrison boxford ...myfords might be too small for you unless a 254 but they are expensive
what do you want to turn? size wise
Do you want a bench mounted machine or free standing
is your floor good
is noise an issue
whats your power availability
or post a link to a chinese lathe you have been looking atLast edited by IanParkin; 17-06-2015 at 12:29 PM.
17-06-2015 #7
Thanks for some of the recommended makers. I was looking at something like this: http://www.dropros.com/DRO_PROS_Sieg_SC8_Lathe.htm
17-06-2015 #8
well thats a similar spec to a colchester student and a similar footprint but just look at the weight difference 385 lbs rather than 1300 lbs
the spindle hole is only 1" a student is 1.5"
everything looks a little weedy on the seig
as an example this one
http://www.ebay.co.uk/itm/Colchester...item2a528dae0d
looks good but depends on what other bits there are to go with it
that one may go for £7-800 ish
A inverter for £200 ish will get you a very nice machine with 8 spindle speeds all with variable speed and full screwcutting and feed speeds...no messing around with loose gears and or belts
a quickchange toolpost transforms it too at £170
a good clean and a new coat of paint will make it gleamLast edited by IanParkin; 17-06-2015 at 04:40 PM.
18-06-2015 #9
Thanks I will look into this I always enjoy revamping machinery, it helps me learn more about the machine.
18-06-2015 #10
This one seems a better bet it has all the toys
http://www.ebay.co.uk/itm/11-Harriso...3D181773643277
Regards
Mike
FOR SALE: Hobbymat MD65 Metal lathe
By craigrobbo in forum Items For SaleReplies: 1Last Post: 13-09-2013, 05:04 PM -
WANTED: OLD LATHE wanted..WORKING OR NOT
By dannymac in forum Items WantedReplies: 0Last Post: 25-01-2012, 10:06 PM -
Starting from scratch, what would you use as a base for a CNC metal lathe?
By m_c in forum Lathes, Lathe Rebuilding & ConversionsReplies: 4Last Post: 23-01-2011, 05:37 PM -
FOR SALE: Coronet Minorette Wood Working Lathe
By AdCNC in forum Items For SaleReplies: 0Last Post: 21-10-2010, 11:54 AM
