Do you have backlash compensation turned on?
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
26-06-2015 #2
I'm getting this also only every half circle so at 90° and 270° and I have backlash comp turned on, which I greatly suspect is causing the problem
Ian
26-06-2015 #3
Backlash comp has to stop at each axis reversal to take up the backlash, so that's what you're seeing. You might need to play with the settings to minimize the pause you're seeing.
Gerry
26-06-2015 #4
Thanks I'll check them again to make sure, what about the speed setting is there a rule for it, I've left it at the basic 20% setting some suggest 50% some even go to 95% - 100%, or is it try what's best kind of setting?
27-06-2015 #5
I don't know, as I've never used it.
Shuttle Accel in General Config also has an effect on it.
I think there's a good video on setting it up on YouTube by Hoss.Gerry
