10-09-2015 #101
Panel finished...
Mesh below the slats...
Bit busy up that end of the shop
Stuck the monitor on the wall, seemed a good place, still working on the keyboard and mouse/trackball, might be a slide-out under the front of the table. I couldn't fit the PC into the main cabinet - not enough space
One odd thing I noticed when motion testing with the proper PC, the X & Z axis worked perfectly but the Y & A needed the "step active low" setting reversing in ports & pins? They sounded very rough and notchy when set the same as the other axes.
This seemed odd as all drives are the same, wired the same and connected to the same BOB????
Any ideas why I need to run two axes reversed signal level???
10-09-2015 #102
If all wired same and the drive doesn't have an active edge Dip switch then probably because setup different in the drive software. Some drives will provide a Dip and most Digital drives you can access thru software.
If none of the above then could just have been set different at the factory,?
10-09-2015 #103
"Active Low" means the drivers are wired with common +5V and step pulse inputs wired to the minus terminals, right?
10-09-2015 #104
10-09-2015 #105
10-09-2015 #106
10-09-2015 #107
Hmm, interesting
Just thought of another difference, the CandCNC MP3000 DTHC uses three parallel cables - one from the pc to the controller and then one to the motor drive BOB and another to the I/O BOB, these last two are new, shorter cables.
Might be worth swapping the old long cables back in???
10-09-2015 #108
Don't think cable length is the cause. Anyway I see only one BOB on the photo and presumed you use Mach3.
Actually did you test all drivers set to "active low"? As far as I understand you have Y and A coupled as master and slave. Wrong polarity might make them "rough" as they need to move in sync while the others may also need low trigger but do not show rough movement because they are single. ??Hmm.
10-09-2015 #109
The mp3000 has two BOB's one for motor control and one for inputs and outputs, yes i am running mach3
All drives were running active low on the test pc, Y and A are slaved in mach and each on their own output.
11-09-2015 #110
CandCNC advised me to up the pulse width to 5us and that seems to have sorted it out, all drives now running the same way.
The Following User Says Thank You to Davek0974 For This Useful Post:
New Build-12x6ft Plasma Table
By F1transportationserv in forum Plasma Table MachinesReplies: 23Last Post: 04-07-2015, 12:14 AM -
Plasma table build, first question....
By Davek0974 in forum Plasma Table MachinesReplies: 51Last Post: 01-08-2014, 03:11 PM -
4' x 4' plasma table build in Canada
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
BUILD LOG: Let The Fun Begain, New build on the Table.
By Bush Flyer in forum DIY Router Build LogsReplies: 63Last Post: 20-11-2013, 09:19 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
