Ok, stuff is on order.
The final result is 50x50x2 for the gantry beam and frame legs, 50x80x2 for the motion support/bed frame.
The final capacity is going to be the half sheet 1250x1250 / 4'x4' size.
Direct drive rack and pinion with a view to change to belt reduction drive or even ballscrews later on.
02-07-2015 #2
Good man thats what like to see no messing around.
02-07-2015 #3
Oh I can mess around, to a point, then I just dive in and go for it.
The top box is the gantry beam, 50x50, the motor sits down the bottom on a plate that swivels on the point shown. It will be spring loaded but restricted so it cannot jump out of the rack and chew it up.
A couple of 75mm gusset plates under the beam on the inside and a rib or two on the outside should stiffen things up a fair bit.
Motors, controllers and rack arrived today :)
The Following User Says Thank You to Davek0974 For This Useful Post:
04-07-2015 #4
Steel came Friday, nice and straight and after a few stress tests (me standing in the middle of a 7m long beam) I realised just how rigid this stuff is
Construction question:
I was thinking of welding on some 100x50x10mm pads under each corner of the motion frame and similar to the top of each leg, then bolting the two parts (welded motion frame/bed and welded leg assembly) together, just to give the opportunity to shim out any variation in leg length etc. Good idea, bad or not worth it???
Next, the bed/motion frame - should I attempt to weld it up as one piece, or weld closing plates flush into the ends of the cross-members, drill/tap and then bolt together?? If yes then how to weld the closer plates in - only way i can think is to heavily bevel the plates then insert and fill bevel with weld tying into the tube sides??? Plates would be 46x76x10mm.
11-07-2015 #5
Got the metal cut today...
Ends squared up and deburred, also cut,drilled and tapped the mount plates for the motion frame and the insert plates for the cross-beams. All ready for a welding session now.
I'm fitting castors and screw-down feet so I can move it about and level it up when assembled.
While I'm gathering info, extraction....
On my little table I built an air-box that sits along the front of the table between the now unused water tray and the slats...
In the front i cut a slot with an area bigger than the pipe cross-section and also slightly tapered towards the middle in an effort to even out the air flow. It works well as long as the unused parts of the table are covered - i get no muck in the shop at all.
It's connected to this radial blower...
I know I can get more out of it by dumping the corrugated pipe and fitting solid duct but it's not going to do a table with an area four times as big.
I don't have any spare power capacity so simply sticking a big-ass blower in there won't do it, need to get smart here. I could maybe run two of these blowers, they are pretty cheap to buy and with external motors they are immune to metallic hot muck.
I had thought about a zoned system - a four zone would work ok with the same blower. Question is, how would I do it???
Any smart ideas on extract??
Don't want water - its only half as effective and makes the machinery in the shop rust.Last edited by Davek0974; 11-07-2015 at 06:16 PM.
12-07-2015 #6
Welded the end plates into the cross-beams...
The leg joint plates onto the main beams...
And the foot plates onto the legs...
Fairly confident in the welds, did a quick destruction test on scrap first, nice and hot concentrating on the thicker parts and washing into the 2mm tube. Joints are ground flush now. Casters will be added soon, to the side of the feet, the feet can be screwed down to lift it off the wheels.
18-07-2015 #7
Got two welded side frames - standing side by side, there is no visible warp, I'm pretty chuffed with that as it was a concern. I levelled the frames between the bench and sawhorse using a spirit level
wedged them up, shimmed the bolting points between frame and top beams then tacked the outer and inner faces, seam welded the lower and upper faces fully, then seam welded the outer face, inner face is left tacked as there is a cross-bream to go in.
Its a bit bigger than my existing one
Looks good though.
Upon assembly i realised i could not weld in the lower cross-beams as planned, I'm not really up to vertical mig yet, cannot get it on the bench, and the underside welds could not be done at all. Answer - make some more bolt fitments out of 10x50mm bar, weld them on and bolt the lower cross-beams in, this will make disassembly easy too.
18-07-2015 #8
If you are trying to weld thin steel and thick steel together you need to run the weld pool down the thick piece of metal and then quickly move across to the thin metal, back to the thick metal, down a bit across just enough, back again to the thick piece, down again etc etc
If you try running a bead equally down the joint, the thin metal will blow out or the thick metal will not get proper penetration.
A CNC machine is never going to generate enough force to cause a properly formed weld to fail, it will probably never get above 1% of the failure point. But if you decide to do nice 'stack of pennies' welds that would make an instructor happy you will be introducing a lot of heat into your frame that will cause stress and distortion over time.
Clamp it, tac it, clean it, back weld an inch at a time and drink lots tea so the heat doesn't build up.
This is an awesome video for demonstrating welding heat distortion, well worth 10 minutes.
The Following 3 Users Say Thank You to D.C. For This Useful Post:
19-07-2015 #9
Amazing, thanks.
Is it the same for Mig though which is a lot faster, I guess it would be???
I would love to be able to Tig like that ;)
19-07-2015 #10
Exactly how i do it, always bias towards the thicker part and set power for the upper end of the thinner part.
I had to cut a 10mm plate off the end of a 50x50x2mm tube yesterday as i welded it on 90deg out
and i was impressed with the penetration i was getting, took some cutting to split the joint.
New Build-12x6ft Plasma Table
By F1transportationserv in forum Plasma Table MachinesReplies: 23Last Post: 04-07-2015, 12:14 AM -
Plasma table build, first question....
By Davek0974 in forum Plasma Table MachinesReplies: 51Last Post: 01-08-2014, 03:11 PM -
4' x 4' plasma table build in Canada
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
BUILD LOG: Let The Fun Begain, New build on the Table.
By Bush Flyer in forum DIY Router Build LogsReplies: 63Last Post: 20-11-2013, 09:19 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
