27-07-2015 #11
Reclaiming some motion distance....
After building the base frame and motion, I decided to build a new floating head using Hiwin and a single carriage - pretty much a standard design. However, this moved my torch 30mm closer to the front of the table than I had planned which left very little over-travel on a full 1250mm sheet - not good.
The first pic is a cross-section of the average torch mount with the Hiwin at the bottom and the circle being the torch clamp.
Now, as I am using wide/stable Hiwin rail, could this idea work?? It regains a valuable 30mm of spare travel on the Y axis.
New Build-12x6ft Plasma Table
By F1transportationserv in forum Plasma Table MachinesReplies: 23Last Post: 04-07-2015, 12:14 AM -
Plasma table build, first question....
By Davek0974 in forum Plasma Table MachinesReplies: 51Last Post: 01-08-2014, 03:11 PM -
4' x 4' plasma table build in Canada
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
BUILD LOG: Let The Fun Begain, New build on the Table.
By Bush Flyer in forum DIY Router Build LogsReplies: 63Last Post: 20-11-2013, 09:19 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
