31-07-2015 #2
Dave, I'm probably being a bit thick....but how are you moving your Z axis up and down? From what I can see you've got your Z stepper mounted on the profile behind the fixed Z front plate? Is there something on the bolttom of your Z front plate that connects to the stepper behind the plate?
31-07-2015 #3
No, the round object sticking out of the top is the coupling for the stepper, it's just not fitted yet :)
It means i can move the z up and down by hand easily.
Inside its a standard screw type affair.
31-07-2015 #4
31-07-2015 #5
Ok, looking at the diagram you quoted, the long 5mm slab at the base is the large flat vertical plate shown in my picture :)
The Hiwin rail/block in diagram is shown on the bottom left of my picture - the block is not fitted yet.
New Build-12x6ft Plasma Table
By F1transportationserv in forum Plasma Table MachinesReplies: 23Last Post: 04-07-2015, 12:14 AM -
Plasma table build, first question....
By Davek0974 in forum Plasma Table MachinesReplies: 51Last Post: 01-08-2014, 03:11 PM -
4' x 4' plasma table build in Canada
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
BUILD LOG: Let The Fun Begain, New build on the Table.
By Bush Flyer in forum DIY Router Build LogsReplies: 63Last Post: 20-11-2013, 09:19 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
....but I'm still not seeing how you're connecting your stepper/screw to the front of the Z axis, your torch holder?
