28-07-2015 #71
Yes, but then there would be a risk of losing the torch alignment when the torch clamp is released to remove the torch. Hopefully with the clamp mounted firmly from the base, it will stay fixed once aligned.
30-07-2015 #72
31-07-2015 #73
Dave, I'm probably being a bit thick....but how are you moving your Z axis up and down? From what I can see you've got your Z stepper mounted on the profile behind the fixed Z front plate? Is there something on the bolttom of your Z front plate that connects to the stepper behind the plate?
31-07-2015 #74
No, the round object sticking out of the top is the coupling for the stepper, it's just not fitted yet :)
It means i can move the z up and down by hand easily.
Inside its a standard screw type affair.
31-07-2015 #75
31-07-2015 #76
Ok, looking at the diagram you quoted, the long 5mm slab at the base is the large flat vertical plate shown in my picture :)
The Hiwin rail/block in diagram is shown on the bottom left of my picture - the block is not fitted yet.
31-07-2015 #77
I get that Dave, but not how the block and torch mount connect to the stepper?
31-07-2015 #78
Ah, right.
Behind the plate lies one of these -
http://www.ebay.co.uk/itm/NEMA23-75m...item4881441268
Its a standard Z-axis unit, screw drive, 2mm pitch, 75mm travel - the motor sits on top and drives the screw direct, the middle block is fixed to the gantry carriage and the upper/lower blocks move with the motor/screw.
Works well.
31-07-2015 #79
Ah ok, so why do you need the rail and block on the plate that's moving up and down? Fine adjustment? Surely mounting the torch holder on the bottom of the plate will be enough?
31-07-2015 #80
New Build-12x6ft Plasma Table
By F1transportationserv in forum Plasma Table MachinesReplies: 23Last Post: 04-07-2015, 12:14 AM -
Plasma table build, first question....
By Davek0974 in forum Plasma Table MachinesReplies: 51Last Post: 01-08-2014, 03:11 PM -
4' x 4' plasma table build in Canada
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
BUILD LOG: Let The Fun Begain, New build on the Table.
By Bush Flyer in forum DIY Router Build LogsReplies: 63Last Post: 20-11-2013, 09:19 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
....but I'm still not seeing how you're connecting your stepper/screw to the front of the Z axis, your torch holder?
