    So, finally got machine built , a 3 axis Gantry router using 4 motors forth motor as " A " axis slaved to y axis ,bought licence for Mach3 and started to install, all went well till tried ref home. only the motor on the y axis turned , the slaved A axis does not, a quick E stop saved any damage, try to fix this has had me pulling my hair out !
    At one stage i had motors going in wrong direction; one side of gantry moving forward while the opposite side went back! and a constant E stop condition!
    I Know am at the stage were z homes but does not retract from home switch and only the Y axis turns !????! HELP.
    Happy are they who dream dreams and are willing to pay the price to see them come true.
    Quote Originally Posted by tonygagey View Post
    Exciting. The forces start at infinity. This is usually bad
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Ok first have you checked in general config that (home slaved with master) is UNCHECKED
    and Angular properties is also unchecked. ..Clive
    And that all the A axis settings match the Y axis.
    Note that in some cases, you may need to modify the homing script to use RefCombination().
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Clive S
    Angular properties was checked , i unchecked them.
    home slaved with master was unchecked and I checked that and it all seems to work! will try again in morning to confirm but so far so good.....
    Clive S
    OK and take note of what Gerry has to say. The motor tuning, Acc and steps etc has to be exactly the same on both the slaved motors. ..Clive
    Does the A axis have it's own home switch, or do you only have one on the Y axis? (Sounds like just the Y axis?)
    Gerry
    Just the y, but have been advised that I needone on A to prevent racking.
    With only one switch, all you need to do is check the "home slave with master" box.
    You won't get any racking with only one switch, but you also will not be able to auto square the gantry when homing.
    Gerry
    I would suggest you really do need two switches then you can adjust one of them to correct any slight squaring issue you might have. The two switches need to be on separate inputs to Mach. ..Clive
  1. CSMIO-IP/S Driving Relays directly
    By cropwell in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:40 AM
  2. Driving me insane
    By Bush Flyer in forum Motor Drivers & Controllers
    Last Post: 14-04-2014, 03:55 PM
  3. Reversed axis on a AXYZ 6010 after installing DNC controller software...
    By RickyThunders in forum Machine Control Software
    Last Post: 12-02-2013, 03:56 AM
  4. Options for installing linear guide rails ?
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 15-10-2011, 12:09 AM
  5. Installing Mitsubishi inverter FR-E520S-2.2K-EC
    By Colin Barron in forum Motor Drivers & Controllers
    Last Post: 25-09-2010, 07:02 PM
