    Hi Guys,
    I have an annoying issue with my router in that it loses position with the resulting tossing of the work piece!!
    This does not happen all the time and when making signs which is 90% of my work it does not normally occur at all probably because of the short duration of the job. I have been cutting some 'pixie doors' for my granddaughter and the problem is apparent as the job runs for approx. 2hrs.
    I thought I had got rid of the problem as I had a faulty USB cable, so replaced with a quality double shielded one! but oh no - the job runs through the roughing stage that's takes 30min no problem (at the moment) I ran the finishing job twice - the first time it failed after 5 minutes and the second time after approx. 60 minutes. The first time it lost position on the x-axis by about 2cm I ran the job from the start again and the second time it failed it was the y-axis and it lost position by about 6cm.
    I thought the job would fail at some point so videoed the second run, reading on the forum I think the stepper is stalling and should probably lower the feed rate. I would appreciate any feedback on the video of the problem!!!
    Earle
    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    It looks to me is that the Z is stalling. It could be that a driver is heating up and shutting down.
    What drivers are you using and what is the voltage of your PS. Can you give more info and pic of the machine. ..Clive
    Hi Clive, thanks for your comment, the router is a Chinese 6040, the ps is 24v and the drivers are YOC335. Feed rate for tool is 20mm/sec or 1.2m/min
    I know this is generic Chinese stuff and I know some people's views on this type of machine but hey I have learnt so much I feel that I could now confidently build something more permanent!
    following the fail in the video I did a goto zero and the y -axis had lost position by about 6/7cm, the up and down movement of the spindle I think is the z-axis doing the correct profile moves as there is a lot of detail in the job.
  5. #4
    I found a few of these drivers for sale but no technical details with a quick Google. Like Clive, I would suspect driver overheating, assuming that obvious things like physical jamming have been ruled out. I saw a very similar set of symptoms when I was setting up my 3D printer; the drivers would just shut down when they overheated and start up again once cooled. Given that your cutting loads are probably quite low, you could try winding the max motor current down a bit, and also check that the motor static current is set to half - if the drivers support these functions... At least, this should be easy to try.
    I'm guessing that the machine stalls in different places each time, so physical jamming seems unlikely, but if you can disconnect the steppers easily it might be worth doing so and checking that the slides move smoothly.
    After that - interference/noise, bad connection, etc - all much more difficult to track down
  6. The Following User Says Thank You to Neale For This Useful Post:
  7. #5
    Thanks Neale,
    When I bought the machine I changed all of the wiring. Created correct earth paths etc - so hopefully got that one covered!! I also installed a UC100 and a different BOB!
    I have stripped the hardware down and checked for any possible seizing but everything seems fine and moves easily.
    I will look into your suggestions to see if that's possible! will report back....
    Earle
  8. #6
    Quote Originally Posted by Earle View Post
    Thanks Neale,
    Earle
    Are you by any chance running this on a laptop. In my opinion USB can give quite a few problems. ..Clive
  1. Random G-code for testing motor tuning.
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 30-10-2019, 08:22 AM
  2. CNC3040 erratic stepper motor operation (fixed)
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 30-12-2012, 07:52 AM
  3. Random Z-Axis plunge
    By gomako in forum Machine Discussion
    Last Post: 15-05-2012, 07:38 AM
  4. Can anyone help me with a router and cutter problem
    By Matt69 in forum Milling Machines, Builds & Conversions
    Last Post: 10-11-2011, 03:47 PM
  5. & todays random 'wet behind the ears' questions are....
    Last Post: 06-07-2009, 10:29 PM
