    Hi Clive and Neale,
    Thanks for your input, Clive I am running this from a dedicated machine!
    Neale, I have changed the max current on the drivers from 3.5A to 2A and the job ran all the way through both the roughcut 30mins and the finish 1h35m YIPPEE...........
    Ok, so without getting too excited as I obviously will try the job again to prove a cure, but what are the consequences for the machine of me reducing the max current through the driver?
    Would it be worth me stripping the driver apart to make sure that the chips are heat sinked correctly?
    Earle
    Quote Originally Posted by Earle View Post
    Hi Clive and Neale,
    Earle
    Earle It will depend on the load you put the machine under ie bigger dia tools or DOC feed rate etc. I am sure your machine would benefit from better drivers with a higher voltage PS supply. It looks like the drivers were overheating and shutting down. ..Clive
    Clive,
    I have a design for a new machine, but I think I will probably build a new electronics package anyway, then I can sell this machine on as a complete working system.
    thanks for yours and Neale's help
    Clive,
    Ok Earle that's all good. Don't buy any electronics as a Kit as they are very rarely matched, You would do betting putting up some drawings for others to critique . Good luck with your new build. ..Clive
    Lower motor current translates into less torque available from the steppers, so potentially lower max speeds and acceleration. The only way to find out is by testing - run a series of tests involving faster and faster speeds, checking that the spindle always returns to the same point. Back off a bit from the fastest working speed to give a bit of leeway. Then ditto varying acceleration. In your case, you might look for higher acceleration at the expense of speed, as with fine work you seldom get up to full speed anyway. That's one reason why no-one can give you hard-and-fast numbers - not only do machines vary but so does the kind of work done.
    Good luck!
    A lot of people that buy the 6040 machines scrap all the electronics from the start, and replace them with quality components. That saves all of the aggravation you'll go through trying to get the machine to work with the stock electronics, until they fail and you replace them anyway.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  7. The Following User Says Thank You to Ger21 For This Useful Post:
  8. #7
    Update:
    i would like like to thank the contributors to this thread. I have run many jobs recently and just run several jobs for clients that have taken 4.5hrs plus each without any failures hitches etc.
    so it appears that lowering the current setting on the drivers has completely solved the reliability issue that I had, the relief is palpable ;-))
    earle
  1. Random G-code for testing motor tuning.
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 30-10-2019, 08:22 AM
  2. CNC3040 erratic stepper motor operation (fixed)
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 30-12-2012, 07:52 AM
  3. Random Z-Axis plunge
    By gomako in forum Machine Discussion
    Last Post: 15-05-2012, 07:38 AM
  4. Can anyone help me with a router and cutter problem
    By Matt69 in forum Milling Machines, Builds & Conversions
    Last Post: 10-11-2011, 03:47 PM
  5. & todays random 'wet behind the ears' questions are....
    Last Post: 06-07-2009, 10:29 PM
