Page 2 of 2 FirstFirst 12
    Lower motor current translates into less torque available from the steppers, so potentially lower max speeds and acceleration. The only way to find out is by testing - run a series of tests involving faster and faster speeds, checking that the spindle always returns to the same point. Back off a bit from the fastest working speed to give a bit of leeway. Then ditto varying acceleration. In your case, you might look for higher acceleration at the expense of speed, as with fine work you seldom get up to full speed anyway. That's one reason why no-one can give you hard-and-fast numbers - not only do machines vary but so does the kind of work done.
    Good luck!
    A lot of people that buy the 6040 machines scrap all the electronics from the start, and replace them with quality components. That saves all of the aggravation you'll go through trying to get the machine to work with the stock electronics, until they fail and you replace them anyway.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  3. The Following User Says Thank You to Ger21 For This Useful Post:
  4. #13
    Update:
    i would like like to thank the contributors to this thread. I have run many jobs recently and just run several jobs for clients that have taken 4.5hrs plus each without any failures hitches etc.
    so it appears that lowering the current setting on the drivers has completely solved the reliability issue that I had, the relief is palpable ;-))
    earle
  5. #14
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Earle View Post
    Update:
    earle
    Ok Earle that's good news I would change out the electronics when you can with a higher voltage p.s. it will then be a different machine
  1. Random G-code for testing motor tuning.
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 30-10-2019, 08:22 AM
  2. CNC3040 erratic stepper motor operation (fixed)
    By DanielF in forum Motor Drivers & Controllers
    Last Post: 30-12-2012, 07:52 AM
  3. Random Z-Axis plunge
    By gomako in forum Machine Discussion
    Last Post: 15-05-2012, 07:38 AM
  4. Can anyone help me with a router and cutter problem
    By Matt69 in forum Milling Machines, Builds & Conversions
    Last Post: 10-11-2011, 03:47 PM
  5. & todays random 'wet behind the ears' questions are....
    Last Post: 06-07-2009, 10:29 PM
