We could probably get this down to 500mm
09-07-2015 #2
Now next is my common sense, later you could prove it in the calculator.
-Then you will need a gantry vertically wide so that 500mm spacing between bearings is achieved.
-2x 150x150x4mm /18kg/m/ separated 200mm and connected every 500mm with braces from 100x100x4mm that all form a leather like structure. Similar to my gantry. Could be reinforced with bolted later steel plate of needed in some direction, though i doubt that you will need for wood.
or simply weld together 2x 200x200x4 or 5mm, though careful engineering here is very important
- You must decide at this point how you will move Z left right, RP or rotating ball nut, how you will move the gantry on long axis, all that before continuing with the gantry design, cause you will need space in between for the rotating nut to pass and so on.
Any thoughts on this design for a gantry setup?
By Dwayne Dibbley in forum Machine DiscussionReplies: 8Last Post: 05-02-2015, 08:49 PM -
Maving Table Gantry Design
By Hubert1946 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 22-10-2014, 09:21 PM -
RFQ: 2 x Gantry Mounting Brackets Needed
By Washout in forum Projects, Jobs & RequestsReplies: 1Last Post: 27-11-2012, 07:34 PM -
Gantry design advice please
By D-man in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 07-11-2012, 04:17 PM -
Gantry design question
By D.C. in forum Gantry/Router Machines & BuildingReplies: 30Last Post: 10-10-2012, 09:11 AM
