Thread: Small but strong cnc machine
Hello.
Thanks for comments.
Clive can you give me any suggestions on how to measure it. Where should I put the weight, and where should I measure for a more accurate value, to see what happens
Alex..
09-07-2015 #2
Hi Alex,
This is how I did it . . . .
http://www.mycncuk.com/threads/7155-...ight=stiffness
Attach a DTI to the collet (mm) and push it with some scales (reads kg so *9.81 to give N). Divide one by the other to give N/mm. Repeat for vertical, fore/aft, and side to side directions. This gives a rough stiffness figure. You will see the sorts of figures achieved by the DIY machines in the post. They will all cut aluminium.
There are some guideline cutting force levels for different materials:
5N wood
50N alum
75N steel
This will of course vary in practice, and the steel force is probably on the low side, but I think it is enough to get a feel for things. You can then estimate the deflection due to the cutting force by inverting the stiffness (do 1 over the stiffness value to give mm/N) and multiplying this by the cutting force (N) for the material you want to cut. This will give (mm) of deflection during cutting. You will have to decide if you think this is acceptable based on the accuracy you want.
Your machine does look on the low stiffness side, but it is small so that will help. Plus it is beautifully made so well done on that front.
The Following 3 Users Say Thank You to routercnc For This Useful Post:
09-07-2015 #3
I did not understand this the first time round but now I do. Thanks for the clear explanation I will have check mine out now.
Edit I appear to get 0.01 at 5Kg pull from just below the collet with a dowel in it on X and YLast edited by Clive S; 09-07-2015 at 10:23 AM. Reason: added text
12-07-2015 #4
Hello.
routercnc, thank you for the explanation. This seems to me a good way to get an idea. I will try this method and post the results here.
Alex..
BUILD LOG: A sufficiently strong machine
By Jonathan in forum DIY Router Build LogsReplies: 42Last Post: 29-03-2014, 10:40 PM -
eBay: small milling machine Sieg Super X3
By Fivetide in forum Items On eBay UKReplies: 0Last Post: 19-11-2012, 01:48 PM -
WANTED: Small Milling machine
By pmcb1011 in forum Items WantedReplies: 1Last Post: 10-02-2012, 10:07 PM -
1st CNC Mill for small machine shop
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 05-09-2011, 10:47 PM -
WANTED: small(ish) manual milling machine
By diy-john in forum Items WantedReplies: 0Last Post: 22-02-2011, 09:04 PM
