Hi all,
Not sure if I should just put all these projects into one thread, so merge if you need to Lee.
Anyway, this video is a project in earning "wife points" :)
Also I've left the"warts" in e.g. the double sided tape not sticking.....
14-07-2015 #2
erm, scuse my ignorance , but if the outside 'Y' arm and the bobbin are both spinning at the same speed then how does the thread get wound on ? ... *blush*
14-07-2015 #3
A good question, I'll ask the "operator" in a sec.......I just made them the same as the original...no idea how the thing works....gulp
14-07-2015 #4
OK the verdict is that the nylon line, which runs in the groove I cut into the larger diameter disc is tensioned using a peg, which then retards the bobbin in relation to the Y arms. So the whole assembly spins at a rate that twists the fleece, but the bobbin is slower and the spun thread then get laid around it.
Hope that makes sense.....Last edited by Washout; 14-07-2015 at 09:25 PM.
RFQ: Ferris Wheel
By cockneyrebel in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-02-2014, 10:00 PM -
MPG or Hand Wheel Pulse Encoder where to buy in UK?
By suesi34e in forum Marketplace DiscussionReplies: 5Last Post: 02-01-2014, 04:41 PM -
Project CNC Router for all
By Anónio Pinho in forum Open Source Designs & PlansReplies: 0Last Post: 30-06-2012, 01:31 AM -
75 mm HAND WHEEL
By Lee Roberts in forum Programmers CornerReplies: 18Last Post: 19-03-2012, 02:58 PM -
RFQ: Aluminium wheel Adapters needed
By 1username in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-02-2010, 10:50 PM
