13-07-2015 #1
probably like most I cant afford one of these expensive wireless tormach or renishaw probes, so I made my own (with the help of a friend)
I purchased one of these
http://www.tormach.com/product_tts_passive_probe.html
its comes with a long cable which you need to hard wire into you control system to work, it works great but the cable is very annoying. so a friend made a IR sender and receiver that can connect to any control system. I use a pmdx126 and the setup for a probe is dead easy. connect the probe directly to the board and all it does it act as a switch, so mach3 knows when its been triggered or not.
the receiver board just uses a relay as the switch so it can connect to any control board.
heres a video of the setup in action, its a very rough setup just to test proof of concept. next I plan to integrate properly
16-07-2015 #2
I have had some Quantum Tunneling Compound for a while now, and my to-do list has a QTC touch probe project (not started - status - don't hold your breath).
New cheap touch probe of fleabay
By Robin Hewitt in forum Probing, Digitizing & ScaningReplies: 17Last Post: 19-08-2015, 09:36 AM -
Touch Probe Project
By Washout in forum Tool & Tooling TechnologyReplies: 2Last Post: 20-11-2013, 12:59 PM -
Touch probe stylus - where to buy?
By Mad Professor in forum Marketplace DiscussionReplies: 3Last Post: 05-08-2013, 07:07 PM -
Touch Probe
By luke11cnc in forum Probing, Digitizing & ScaningReplies: 28Last Post: 31-01-2012, 01:16 AM -
RFQ: Touch Probe - Lathe job
By cooliced in forum Projects, Jobs & RequestsReplies: 2Last Post: 16-11-2011, 07:12 PM
