Good news to report on this. Cleaning the commutator did the trick. No more popping and tripping even at full load. I will still need new brushes shortly but at least I now have the time to research and maybe even replace the motor with something better.
After doing the first clean up with emery paper, I read that using emery is not such a great idea since the particles can get between the segments and cause shorts. However I thoroughly cleaned between the segments with a soft brush on a dremel and in fact the gap between the segments is big enough easily see any major debris. Just mentioning this in case someone is reading this thread with the same problem.
I actually now think the major issue was carbon build up between the segments.
sieg X2 clone mill again......
By doc watson in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 20-08-2014, 02:23 PM -
Romi EZ-Path S Lathe crt replacement
By Nemo1966 in forum MonitorsReplies: 5Last Post: 07-10-2013, 04:25 PM -
FOR SALE: bf20 g0704 spindle motor
By fragger6662000 in forum Items For SaleReplies: 0Last Post: 07-11-2011, 11:12 PM -
FOR SALE: (G0704 SPG 2217 Champion 20V Mill Warco WM 16) DC motor
By fragger6662000 in forum Items For SaleReplies: 0Last Post: 09-10-2011, 05:59 PM -
Chester tools champion 16v milling machine conversion
By NICKMODELMAKER in forum General DiscussionReplies: 3Last Post: 26-02-2010, 09:29 AM
