Thread: Spindle 2?
Hi all
Any one used the spindle 2 board? For £20 + speed controller, it looks like a good option for controlling routers etc
Is a VFD and 3 phase motor worth the money?
09-06-2009 #2
Yes used a few of them, Roy developed them initially for us as the Sieg and the American KB controllers have the pot at mains potential.
Just wiring straight in using the same logic supply as the rest of the breakout / driver system causes lovely bright multi coloured sparks and bangs [ don't ask ]
Like all of Roy's boards I have used, they have worked with no problems and done what it says on the box which isn't hard as they don't come in a box.
.John S -
10-06-2009 #3
I have a VFD and 3phase on the lathe, and since it accommodates two motors I plan to change the mill to a 3phase and run both off the same VFD (not at the same time of course!)
10-06-2009 #4
Cheers guys , what VFDs and power motors are you using, Am I correct in assuming that a 3ph motor is more powerful? or is that only when they are run at 415 volts?
10-06-2009 #5
All sorts, some generic Taiwanese el cheapo ones, IMO's Telemechaniques, Yaskawa and Fuji.
Motor powers from 0.25 Hp up to 7.5 Hp
Technically horse power is horsepower regardless of single or three phase, what does alter is the amount of amps pulled to get this power.
However the 3 phase goes come out on top as getting 3 pulses per rev it doesn't bog down as much as a single phase motor with one pulse per rev when a load is applied.
They are smoother, less vibration and with a VFD the 3 phase can have speed control, something the single phase one can't have.
.John S -
10-06-2009 #6They are smoother, less vibration and with a VFD the 3 phase can have speed control, something the single phase one can't have.
Do these only control the speed and therefore have reduced power as well?
Seen a couple of VFDs on ebay for £150. dose this seem about right?
10-06-2009 #7
Only if they are PM motors (permanent magnet). 1ph motors with AC field coils cannot be controlled this way as they are synchronous to the AC input frequency. PM motors are low-fractional HP output.
Thats about right for a sub-1kw (.5 - 1HP) VFD. You must match the VFD to the motor.
15-02-2011 #8
I'd also recommend Yaskawa & FUJI. I wouldn't recommend ABB to anybody.
Has anybody worked with Yaskawa's latest drive?
http://www.clrwtr.com/Yaskawa-A1000-Drives.htm
10-06-2009 #9
It's always worth looking at a 415-440vac one (just use a step-up transformer and a 440v motor like my lathe - the 1.5kw one I bought for <£20, and a spare for a tenner ) or, 240v ones that are described as three phase input (since almost all will work with single phase input).
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
