Thread: Spindle 2?
    A lot of people who use a VFD to power two machines fit a red 3 phase socket on a flying lead and use that to swap over.
    If the machines are close some have a wall mounted socket and use two plugs, one per machine.
    Big No No is NEVER unplug whilst running, OK to unplug whist plugged into mains and switch on but not running.
    One thing to watch when sharing is the motor load in amps as these 'should' be set per motor.
    Say you have a 2 Hp VFD and a 2 hp motor drawing 8 amps and a 1Hp drawing 4 amps. When you swap over you need to change the motor load parameter to match. Depending on the VFD there may be other functions to change as well.
    John S -
    Typical, being the cheap skate that I am I thought I could save a few quid with the CHR spindle controller and a £10 speed controller. But looks like Im back the VFD route! :sad:
    Then again, Bill what was that step up transformer system? I know you can step up the voltage but how dose the 3 phase bit work?:confused:
  2. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  3. Spindle lock mechanism for 2.2kW china spindle
    By Jonathan in forum Generic Chinese Spindles
    Last Post: 13-08-2012, 08:39 PM
  4. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
  5. DIY Spindle - What type of bearings are best suited for a spindle.
    By 8iggles in forum Spindles & Drive Motors
    Last Post: 09-02-2011, 10:15 PM
