looking at replacing my sem servo motor with something like this
http://www.ebay.co.uk/itm/3KW-WATER-...item2a52124388
as my machine has an ATC I need to get a pulley attached to the end of the spindle.
the plan would be to mod and existing pulley rather than make a new one, so question is where do I find thread details of an ER20?
many thanks
31-07-2015 #2
Is this what you are looking for http://www.amazon.com/Dorian-Tool-ER.../dp/B00CB0Y7SI M25 x 1.5 Thread ..Clive
31-07-2015 #3
perfect many thanks
31-07-2015 #4
Andy Are you sure the spindle you linked to will do the job as they don't have any torque at low speeds say lower than about 3.5K rpm not like a servo ..Clive
31-07-2015 #5
well...
I have a denford triac, its got a sem MT30U4 servo motor -
http://igor.chudov.com/projects/Brid...ata_Manual.pdf
although a very good motor with lots of torque it only does 4000rpm, so my feed rates are really slow. but yes I can do a 2mm deep cut in ally with an 8mm cutter, or a 1mm deep cut in ally with a 20mm cutter without any trouble.
what I was thinking was to get one of these Chinese spindles, swap the bearings out on my mill so they can handle the speed and do a 2:1 reduction. so id be looking at 12000rpm. so I would gain a bit more torque.
I don't actually need to run the spindle at slow speeds, I use threadmills for tapping etc...
31-07-2015 #6
Ok I was wondering if you needed position control on the spindle for the atc. That's not so easy on the spindle you linked too.. ..Clive
03-11-2015 #7
03-11-2015 #8
to little info on the Chinese spindles so ive not done it
03-11-2015 #9
The Following User Says Thank You to Chaz For This Useful Post:
Denford Triac VMC
By fidia in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 19-08-2016, 08:18 AM -
FOR SALE: ER20 DIY Spindle Parts
By Mad Professor in forum Items For SaleReplies: 1Last Post: 03-11-2012, 06:51 PM -
Conversion of ER16 spindle to ER20
By Tenson in forum General DiscussionReplies: 3Last Post: 14-07-2012, 05:19 PM -
Chinese vfd/spindle question
By Shinobiwan in forum Tool & Tooling TechnologyReplies: 2Last Post: 02-03-2012, 02:02 AM -
Denford Triac Spindle Fault
By Sam_Smith in forum Denford MillsReplies: 5Last Post: 04-05-2011, 11:07 PM
