    Andy Are you sure the spindle you linked to will do the job as they don't have any torque at low speeds say lower than about 3.5K rpm not like a servo ..Clive
    well...
    I have a denford triac, its got a sem MT30U4 servo motor -
    http://igor.chudov.com/projects/Brid...ata_Manual.pdf
    although a very good motor with lots of torque it only does 4000rpm, so my feed rates are really slow. but yes I can do a 2mm deep cut in ally with an 8mm cutter, or a 1mm deep cut in ally with a 20mm cutter without any trouble.
    what I was thinking was to get one of these Chinese spindles, swap the bearings out on my mill so they can handle the speed and do a 2:1 reduction. so id be looking at 12000rpm. so I would gain a bit more torque.
    I don't actually need to run the spindle at slow speeds, I use threadmills for tapping etc...
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Ok I was wondering if you needed position control on the spindle for the atc. That's not so easy on the spindle you linked too.. ..Clive
    nope don't need anything like that.
    ive never been able to find a torque curve for one of these Chinese spindle are there any? im assuming its peak torque comes at full power?
    Quote Originally Posted by andy_con View Post
    I suppose it should be in the manual but who knows.
    hahaha funny... ;-)
    Chinese manuals don't have any information you need, just the information you don't need
    hahaha funny... ;-)
    Being up north you have to have a sense of humour If jonathan was on line he would most likely know that sort of info. Nice spindle though.
    be nice if I can get it in and working.
    im just in the process of adding a 10 station atc to the machine, its currently only got 6
  1. Denford Triac VMC
    By fidia in forum Milling Machines, Builds & Conversions
    Last Post: 19-08-2016, 08:18 AM
  2. FOR SALE: ER20 DIY Spindle Parts
    By Mad Professor in forum Items For Sale
    Last Post: 03-11-2012, 06:51 PM
  3. Conversion of ER16 spindle to ER20
    Last Post: 14-07-2012, 05:19 PM
  4. Chinese vfd/spindle question
    By Shinobiwan in forum Tool & Tooling Technology
    Last Post: 02-03-2012, 02:02 AM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
