The compressor is rated at 8 bar. I've had the head off, but gaskets seem ok. The valve holder plate with the reed valves appears ok, but does rattle when shaken.
05-08-2015 #2
whats the piston look like ? it could be blowing by .... edit
a diaphragm ... it might have a hole in it ?
also does the compressor switch of when it gets to 2 bar ? or does it just run non stop ?
05-08-2015 #3
I would imagine it's running none stop because it can't attain the cut out pressure so there's a leak, if it's stopping @ 2 Bar it's the pressure switch.
05-08-2015 #4
ditto ;) thats wat i fought
06-08-2015 #5
It does not cut out and charges continually. The piston is ok and so are the head gasket and base gasket.
06-08-2015 #6
I had a similar problem with a compressor - it had a mucky reed valve, so it wouldn't close and just pumped the same air all the time. So make sure the valves are clean and operating OK. If the valve plate rattles as you say, then this sounds to be the culprit.
10-08-2015 #7
Examined the reed valve and yes that's the problem. Even when closed you can see day-light around one of the edges, looks like the plate has lost a bit of material over-time. Will order a new plate assembly from MachineMart tomorrow. Thank you all for your responses!
01-09-2015 #8
Confirmed, it was the valve holder plate. Compressor works like a dream now. Thanks for the help.
What to look for in an air compressor.
By Philly in forum Tool & Tooling TechnologyReplies: 28Last Post: 27-04-2013, 11:02 PM -
Compressor specification for alu chip blower
By Saracen in forum Machine DiscussionReplies: 20Last Post: 12-01-2013, 09:17 PM -
Has my air compressor died?
By Jonathan in forum General DiscussionReplies: 9Last Post: 15-10-2012, 12:08 AM -
Which air compressor?
By newtoid1986 in forum General DiscussionReplies: 7Last Post: 12-12-2011, 04:07 PM -
Air compressor - faulty, how do I get the motor out?!
By HankMcSpank in forum General DiscussionReplies: 5Last Post: 26-10-2009, 11:33 AM
