Thread: Making a Die?
I was thinking of making one myself. I imagine a couple of thick plywood boards, one holding the cutting blade and then pressing them together with the material between. A screw in each corner would allow me to get the required pressure. That's my idea anyway.
I can cut the board with a slot for blade on my mill, but the thinnest bit I have is 3mm. How thick is standard cutting blade?
If my plan sounds sensible I'd love to get some cutting blade from you!
How does one normally form and fix the blade into the press board? Just bend by hand with pliers and fix with epoxy?
Thanks,
SimonLast edited by Tenson; 05-08-2015 at 08:05 PM.
05-08-2015 #2
The cutting rule is about .5mm thick
creasing rule is thicker
the rule is just pressed into place
dont underestimate the pressure you will need to cut even one sheet of paper with a form like this
presses to do such a thing are very heavy and exert mega pressure
and are precision things
one way of doing it is to place the form on a base board then place the board that you want to cut on top and then run a roller over the board
forms are made to 0.918" high
the roller needs to run at that height over the form
you place bits of foam rubber next to the blade to push the cut edges away from the blade
I think your idea of 2 boards with screws is possible for such a simple form but very slow...how many cuts do you want to make?
05-08-2015 #3
I need to cut about 100 pieces. I was thinking of putting 4 shapes on one press. Perhaps that is too ambitious if you say it needs loads of pressure. Still I can experiment. The roller is a good idea.
How do you usually cut the form with a slot only 0.5mm thick? Do you use a mill? When yo say the blade is pressed into place I guess you mean into a grove pre-cut to shape.
I was thinking of something like this press, which I use for veneering A4 size panels.
05-08-2015 #4
Commercially they are done with a laser but one off simple ones with a large fret saw
you will never get enough pressure with that press to cut 4 at once in the middle
you may do 1 if the bolts are close to the cutter
05-08-2015 #5
06-08-2015 #6
Known as a steel rule die or knife.
Knw someone who uses them for leather , with a 17 ton clicker press...
12-08-2015 #7
Making horns.
By simonms in forum Machine DiscussionReplies: 17Last Post: 06-02-2015, 07:51 AM -
Making decisions about my first CNC
By TBJ in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-01-2015, 09:21 PM -
Making a little box
By mark84 in forum General DiscussionReplies: 5Last Post: 11-03-2014, 11:34 PM -
Mold Making?
By Shinobiwan in forum Moulding MachinesReplies: 10Last Post: 27-02-2013, 02:15 AM -
Making a Jig
By Wobblybootie in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 06-06-2010, 11:17 AM
