Thread: not enough current for relays?
Without a diagram of your particular situation, all we have to go on is this....
If you get a multi-meter & see what the resistance is between the Pokeys57CNC 0V rail & the relay board's 0V rail ....if it's high resistance , then there's no common path (& therefore this is why your relay's aren't switching).... you will need to link the 0Vs on both boards together. Voltage is always 'with reference to another point' ...i.e. the 5V on your Pokeys57CNC is in reference to the Pokeys57CNC 0V, the 5V on your relay board is in reference to your relay board's 0V...the only way you can make the 5V on your Pokeys57CNC mean anything to your relay board is to commonize the 0V rails on both boards....join them together.Last edited by HankMcSpank; 17-08-2015 at 11:44 AM.
CSMIO-IP/S Driving Relays directly
By cropwell in forum CS-Lab (CSMIO)Replies: 10Last Post: 02-01-2017, 01:40 AM -
Using current as cutting force indicator?
By mitchejc in forum General ElectronicsReplies: 10Last Post: 13-01-2015, 05:09 AM -
question about relays
By frankman in forum General ElectronicsReplies: 3Last Post: 23-01-2012, 07:47 AM -
Current Set Resistors.
By NzOldun in forum Motor Drivers & ControllersReplies: 1Last Post: 20-06-2011, 08:38 AM -
G540 Current set resistors
By blueseidboy in forum Motor Drivers & ControllersReplies: 3Last Post: 23-08-2010, 02:21 PM
