Thread: 8 x 4 build
    just throwing in my gantry design, the z axis is inside the x axis frame which is supported by 2 200x100mm 10mm thick mild steel box, the z axis has a maximum height of 250mm (would like to go higher but 250mm seems to be the recommended height for rigid and stability.)
    what do you think?
    cheers
    ash
Name:	frame and gantry 2.jpg
ID:	15898   Click image for larger version.
Name:	frame and gantry 3.jpg
ID:	15899   Click image for larger version.
Name:	frame and gantry 4.jpg
    Are you going to use screws at that length ? driven with a motor on the end.
    do you mean ball screws? if so then yes both sides :) using nema 34 motors and servo drivers.
    cheers
    ash
    D.C.'s Avatar
    Have you a read through this build log? Lots of renderings at the start and photos of the frame later on that might help.
    http://www.mycncuk.com/threads/6619-...2060#post52060
    Quote Originally Posted by reefy86 View Post
    cheers
    ash
    Ok then have factored in the whip of the screws at that length etc.
    hi clive, what do you mean have factored in the whip?
    cheers
    cheers
    Ball screws have a critical speed that you can reach before they start to whip I am not an expert on this but I would have thought that if you are using screws that long you might need rotating ball nuts. Do a search on here there has been plenty of talk about it.
    i used rotating nuts, on my 8x4 build because of the whip effect Clive mentions.
    skip to about 1:15
    http://www.mycncuk.com/threads/8242-...t=wall+mounted
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. BUILD LOG: New Build - For Your Amusement - MK-2 build
