Thread: 8 x 4 build
  1. #21
    update on design thanks to the help from Dean :) the frame is made out of 90mmx90mmx5mm mild steel and 200mmx100mmx10mm on both y and x axis. all plates are 25mm thick apart from the end plates that connects to the ballscrews as they will be tentioning the screws so they are 30mm, ball screws are r2020's on x and y and z axis is r1610. the y axis will have a rotating ballnut and ball screws fixed both ends and then tentioned. on both y and x axis i will be using 25mm profile rails and 15mm on the z axis. im not starting with electronics yet but i do know ill be using nema 23's 3nm but still learning here.
    thoughts anyone?
    Ash
ID:	17694Click image for larger version.
ID:	17695Click image for larger version.
ID:	17696Click image for larger version.
Name:	cnc machine.17.jpg
  2. The Following User Says Thank You to reefy86 For This Useful Post:
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. BUILD LOG: New Build - For Your Amusement - MK-2 build
