    im after some advice on vacuum pumps for a vacuum table setup.
    i want to do exactly this -
    no idea if its the right sort of table, but been looking at this table as its the perfect size for my mill
    http://vacuumtables.co.uk/product/va...ble-vt3020-gr/
    would this pump do and im assuming im going to need a liquid seperator as my mill has flood coolant?
    http://www.ebay.co.uk/itm/Robinair-R...c=1&rmvSB=true
    thanks
    I think it should work. A friend has similar size pump and the plate you aim to use is fairly small.
    ok thanks
    im assuming as im machining all the way through a vac-mat will be better as it wont suck as much coolant in and a proper holed matt?
    https://www.hoffmann-group.com/GB/en...ats-1/p/385040
    It will not suck dust and metal, that's for sure, due to the micro holes. It will hold steadier also, due to friction.
    how does it work with a normal holed mat? does the table suck metal into the pump?
    (sorry ive never used a vacuum table before)
    Depends how fine is the sucking hole. Not the vacuum hole you see on pictures 3-6mm, but the real sucking hole in the vacuum hole center, it could be 0.5-1mm . Its a good idea the vacuum table to be made from 2-3 pieces and that could be dismantled for cleaning or repair.
    The vacuum table from the first link was ok and they have mats. any mat from superstore 2-5eur per meter will do the job, some experimenting is needed. cause they sell ridiculously expensive the mats.
    Or just DIY around the vac-mat
    My friend Ralf use's one of these pumps http://m.ebay.co.uk/itm/271844104827 for his diy vacuum system quite successfully, below is the build video from his youtube channel:
    https://youtu.be/viVbB5mzSaw
    There are some other videos there too, detailing his machine and the vacuum setup.
    .Me
    We develop a thin film for hard works may be it can do the job? Please take a look at the movie. https://www.youtube.com/watch?v=PbCqkUomf5M
  9. The Following User Says Thank You to YulianY For This Useful Post:
  1. I want a vacuum table!
    By Tenson in forum Machine Discussion
    Last Post: 08-01-2014, 07:40 PM
  2. Vacuum Table Advice
    By Minium in forum Milling Machines, Builds & Conversions
    Last Post: 13-11-2012, 09:52 AM
  3. Custom Vacuum Table 'Hold Down' System - piping/valve advice
    By FlightCaseCo in forum Machine Discussion
    Last Post: 16-01-2012, 06:56 PM
  4. Replies: 1
    Last Post: 01-01-2012, 12:34 AM
  5. DIY Vacuum Table
    By templecorran in forum Machine Discussion
    Last Post: 10-11-2010, 12:11 AM
