Thread: Vacuum table Setup Advice
08-09-2015 #15
Ah now that makes perfect sense thanks.
When you say the system works, I know the table and bits work as work peice does get held down just not strong enough.
I'm assuming you wpuld only use a compressor to test not as a final solution as the compressor would need to be running for an hour straight to draw a vacuum whilst you do the machining?
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
