Thread: Vacuum table Setup Advice
10-09-2015 #30
I would use the compressor setup to resolve all table, mat and fixture issues. Once i know that all functions and what exactly i need i would buy then the proper sized vacuum pump.
Jumping to buy the first vacuum pump seen is not a good idea. From what i see from the picture you are again on the wrong path.
You need a 2 stage low volume high pressure vacuum pump / but enough volume/ , no high volume low pressure vacuum pump. These are not the proper technical words may be , just to have an idea what i am talking about.
This is exactly the vacuum pump my friend bought from ebay. he is using it for a vacuum chamber. I am thinking of buying one also. It seems to me its up to the task as i have seen it in real life. Its a sucker. 7cfm.
Check all specifications again including electrical, ask the vacuum table dealer or manufacturer if its ok and buy that sucker. It will be extremely unacceptable new, just check price :-)
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
