  1. #31
    Quote Originally Posted by GEOFFREY View Post
    Surely for wood the bit needs to fully penetrate the work so therefore a sacrificial (mdf?) board is still required. What type of expanded plastic board do you use as most plastics are virtually impermeable, or do you use some kind of foam board (polystyrene?). G.
    3-4mm expanded PVC, used usually as backing for large photo prints. have friends with photo studio and use for free the rests. its sth like 6euro per sq m , sold on sheets of 3x2m. Easily cut wit cutter/exacto knife/. One of my favorite materials.
    also from them i get super strong ultra thin double tape sheet, used to stick photo prints to methacrylate. This i use on small pieces for fixing the center not to flap. very strong stuff, if used bigger is impossible to separate. if cutter passes through it though the last cut should be way slower.
    If the machine is precise and the table is surfaced plastic or even better- some phenolic sheet, the bit does not need to penetrate more than 0 for wood and plastic.Its very pleasant to the eye how it cuts through and does not damage the surface. of course after auto 0 procedure, preferably using calibrated material touch plate.
    Only for aluminum it needs to go deeper as its slightly pushes the last material instead of cuttingwhen set to cut to 0 depth.
  1. I want a vacuum table!
    By Tenson in forum Machine Discussion
    Last Post: 08-01-2014, 07:40 PM
  2. Vacuum Table Advice
    By Minium in forum Milling Machines, Builds & Conversions
    Last Post: 13-11-2012, 09:52 AM
  3. Custom Vacuum Table 'Hold Down' System - piping/valve advice
    By FlightCaseCo in forum Machine Discussion
    Last Post: 16-01-2012, 06:56 PM
  4. Replies: 1
    Last Post: 01-01-2012, 12:34 AM
  5. DIY Vacuum Table
    By templecorran in forum Machine Discussion
    Last Post: 10-11-2010, 12:11 AM
