Thread: Vacuum table Setup Advice
19-09-2015 #35
Here is the vid in YouTube now.
The connection and bracket are named KF25. plenty of them cheap in ebay.
What you will need more for the system:
-outlet- additional bracket and oil trap filter for the exhaust oil vapors, which is basically a box with sponge inside
-inlet- at least another bracket and hose adapter. Inline air filter at least 5 micron, so no dust enters the sucker. Maybe cheap car fuel filter or sth similar. Liquid separator?
-2 capacitors so you can run it 2 phase. its 3 phase originally. One for start and other to run, see video.
additional notes:
-I don't see a reason for an air reservoir as the system will be very tight and it will take time to achieve pressure with big deposit. Switch on, use and then switch off. This pump has nothing to do with the cheap ones/similar price new/ sold at ebay with similar ratings in CFM, though i believe even they will work ok as here the purpose is not removing the last atom...
-digital vacuum gauge is recommended, though even a analogue will work ok. i don't see actual need for switch except to make some sort of bleed valve when certain vacuum is reached. hopefully there will be some smallish leaks in the diy seal anyway, cause that thing is a sucker.
I am very inclined to grab one. If you are even more patient next week i will go there again, so can try it with some improvised vacuum fixture and make video of it.
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
