Thread: Vacuum table Setup Advice
17-08-2015 #1
im after some advice on vacuum pumps for a vacuum table setup.
i want to do exactly this -
no idea if its the right sort of table, but been looking at this table as its the perfect size for my mill
http://vacuumtables.co.uk/product/va...ble-vt3020-gr/
would this pump do and im assuming im going to need a liquid seperator as my mill has flood coolant?
http://www.ebay.co.uk/itm/Robinair-R...c=1&rmvSB=true
thanks
17-08-2015 #2
18-08-2015 #3
ok thanks
im assuming as im machining all the way through a vac-mat will be better as it wont suck as much coolant in and a proper holed matt?
https://www.hoffmann-group.com/GB/en...ats-1/p/385040
18-08-2015 #4
18-08-2015 #5
18-08-2015 #6
Depends how fine is the sucking hole. Not the vacuum hole you see on pictures 3-6mm, but the real sucking hole in the vacuum hole center, it could be 0.5-1mm . Its a good idea the vacuum table to be made from 2-3 pieces and that could be dismantled for cleaning or repair.
The vacuum table from the first link was ok and they have mats. any mat from superstore 2-5eur per meter will do the job, some experimenting is needed. cause they sell ridiculously expensive the mats.
Or just DIY around the vac-mat
23-08-2015 #7
anyone know anything about these pumps?
http://www.mastercool.com/product/90...-single-stage/
seems fairly decent, says its designed for continuous use, there are many brand new ones on ebay so am rather tempted
I'm assuming 6cfm will be enough power?
07-09-2015 #8
been trying to do a vacuum table setup but an failing badly.
I purchased this -
http://www.ebay.co.uk/itm/CNC-Vacuum...item487aa50799
and today I got the uni-jet 75
http://www.cattaniesam.co.uk/suction...ry/uni-jet-75/
the guy from ebay recommends 3cfm, if I worked it out correctly the uni-jet does 1250L/min which is 44cfm. so in theory plenty of suck.
got a 32mm pipe coming out of the vacuum pump, then just before the table reduced down to 10mm as that's what you need to plug into the vacuum table. length of pipe maybe 2 metres
when on and you try to move the work piece with your hand, you can but its bloody hard, its stuck down pretty dam well. you have to really really force it to get it to move with your hand. but when trying to machine it, it seems to move so easily.
I'm using a 6mm cutter, with a z depth of -0.5mm with a feed rate of 300mm/min
anyone got any advice?Last edited by andy_con; 08-09-2015 at 08:15 AM.
08-09-2015 #9
UNI-JET 75
Max. vacuum level: 140mbar (continuous service)
Are you sure you have got the right pump?
you need ~25 Inches Hg which is around 850mbar vacuum
My air compressor at home pulls on the inlet 0.94 bar =~ 940 mbar =705.05993009406 mmHg
Your pump is way off, it seems.
Who told you to look for CFM? you dont have 4x8 machine where you need 20HP pump with CFM rating.
Unscrew your air compressor/ what ever size, 1-2hp is ok/ inlet filter and connect the vacuum table and check what i am talking about. Dont worry about the continuous use, nothing will burn. In fact it runs cooler. Temperature rises from compression, not suction. If your compressor is newish it will make damned good vacuum.
08-09-2015 #10
Ok, so I have the wrong pump?
Not sure what you mean by
What's an air compressor got to do with a vacuum table
Sorry I don't fully get your reply
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
