Thread: Vacuum table Setup Advice
08-09-2015 #9
UNI-JET 75
Max. vacuum level: 140mbar (continuous service)
Are you sure you have got the right pump?
you need ~25 Inches Hg which is around 850mbar vacuum
My air compressor at home pulls on the inlet 0.94 bar =~ 940 mbar =705.05993009406 mmHg
Your pump is way off, it seems.
Who told you to look for CFM? you dont have 4x8 machine where you need 20HP pump with CFM rating.
Unscrew your air compressor/ what ever size, 1-2hp is ok/ inlet filter and connect the vacuum table and check what i am talking about. Dont worry about the continuous use, nothing will burn. In fact it runs cooler. Temperature rises from compression, not suction. If your compressor is newish it will make damned good vacuum.
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
