Thread: Vacuum table Setup Advice
11-09-2015 #31
3-4mm expanded PVC, used usually as backing for large photo prints. have friends with photo studio and use for free the rests. its sth like 6euro per sq m , sold on sheets of 3x2m. Easily cut wit cutter/exacto knife/. One of my favorite materials.
also from them i get super strong ultra thin double tape sheet, used to stick photo prints to methacrylate. This i use on small pieces for fixing the center not to flap. very strong stuff, if used bigger is impossible to separate. if cutter passes through it though the last cut should be way slower.
If the machine is precise and the table is surfaced plastic or even better- some phenolic sheet, the bit does not need to penetrate more than 0 for wood and plastic.Its very pleasant to the eye how it cuts through and does not damage the surface. of course after auto 0 procedure, preferably using calibrated material touch plate.
Only for aluminum it needs to go deeper as its slightly pushes the last material instead of cuttingwhen set to cut to 0 depth.Last edited by Boyan Silyavski; 11-09-2015 at 10:31 PM.
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
Vacuum Table Advice
By Minium in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 13-11-2012, 09:52 AM -
Custom Vacuum Table 'Hold Down' System - piping/valve advice
By FlightCaseCo in forum Machine DiscussionReplies: 4Last Post: 16-01-2012, 06:56 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
DIY Vacuum Table
By templecorran in forum Machine DiscussionReplies: 18Last Post: 10-11-2010, 12:11 AM
