Okay, allow me to state it again:
Using unsupported shaft in this machine will be a waste of money and effort!
Building this thing in steel allows it to be a good performer, using unsupported shafts will allow flex, making the results no better then the same thing built of plywood.
Then two general remarks on the design:
1: It seems to me that you will not be able to assemble this thing, as the nuts will be falling out all the time.
2: If you add tabs+rectangular holes here and there to position parts, you can probably glue the thing together, if you choose the right kind of epoxy.
If not using epoxy you can still use an occasional spot weld to fix a tab in its hole.
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
Welding bench
By Boyan Silyavski in forum Metalwork Project ShowcaseReplies: 4Last Post: 12-07-2015, 05:01 PM -
RFQ: RFQ TIG welding
By Robin Hewitt in forum Projects, Jobs & RequestsReplies: 9Last Post: 01-02-2013, 10:41 PM -
Welding Consumables
By GTJim in forum Welding, Brazing & EquipmentReplies: 5Last Post: 13-12-2012, 01:33 PM -
TIG welding
By Robin Hewitt in forum Welding, Brazing & EquipmentReplies: 2Last Post: 03-04-2012, 10:38 PM
