Eurikain,
Listen to the sound of bearings moving in this video:
http://www.youtube.com/watch?v=bGbWBDtzydw
It sounds bad.
Very bad.
Very, very bad.
I'm guessing this video or something like it is where you got the idea for DIY supported rails.
It is a bad idea.
Very bad.
Very, very bad.
The reason why everyone is giving you negative feedback is because it is a bad idea, so ditch it and move on. If it helps any, hiwin rails from hobby machines have a good second hand market value. When you outgrow your machine you can recover a lot of the price by selling them on.
PS I'm the resident village idiot, annoying people with my hair-brained ideas, even I figured out that DIY supported rails was a non-starter.
29-08-2015 #2
Hi ! Sorry for the late reply, I've been a bit busy :)
I hear you all, and I will take your advice. I know, DIY supported rails are not the way to go. I hear you. Even if this is not going to work, I think that the profile method was going to work, just not with steel, or made differently with short pieces. I think DIY rail is possible, but you need to get the supports milled from ALU or steel and then tap them. What I am just explaining here is that ROUND fully supported rails don't seem efficient to me cost / strength wise. I've run a couple simulations in SW and that confirmed my idea. You could semi-support a round rail with at least 1/2 of the material used in fully supported chinese rails. Of course, getting those parts machined may be expensive, unless you've got a CNC within hand's reach, or know someone that can get them milled.
That said, supporting the rails with bolts is a silly idea, I agree.
06-09-2015 #3
@Boyan
I requested a quote from my seller Kevin and from Fred at BST automation for SBR rails.
Kevin asks for $305, Fred for $345 ;)
07-09-2015 #4
08-09-2015 #5
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
Welding bench
By Boyan Silyavski in forum Metalwork Project ShowcaseReplies: 4Last Post: 12-07-2015, 05:01 PM -
RFQ: RFQ TIG welding
By Robin Hewitt in forum Projects, Jobs & RequestsReplies: 9Last Post: 01-02-2013, 10:41 PM -
Welding Consumables
By GTJim in forum Welding, Brazing & EquipmentReplies: 5Last Post: 13-12-2012, 01:33 PM -
TIG welding
By Robin Hewitt in forum Welding, Brazing & EquipmentReplies: 2Last Post: 03-04-2012, 10:38 PM
