    Hi ! Sorry for the late reply, I've been a bit busy :)
    I hear you all, and I will take your advice. I know, DIY supported rails are not the way to go. I hear you. Even if this is not going to work, I think that the profile method was going to work, just not with steel, or made differently with short pieces. I think DIY rail is possible, but you need to get the supports milled from ALU or steel and then tap them. What I am just explaining here is that ROUND fully supported rails don't seem efficient to me cost / strength wise. I've run a couple simulations in SW and that confirmed my idea. You could semi-support a round rail with at least 1/2 of the material used in fully supported chinese rails. Of course, getting those parts machined may be expensive, unless you've got a CNC within hand's reach, or know someone that can get them milled.
    That said, supporting the rails with bolts is a silly idea, I agree.
    @Boyan
    I requested a quote from my seller Kevin and from Fred at BST automation for SBR rails.
    Kevin asks for $305, Fred for $345 ;)
  3. Quote Originally Posted by eurikain View Post
    @Boyan
    I don't know Kevin but Fred is a reliable seller.
    Quote Originally Posted by JoeHarris View Post
    Exactly. i wouldn't trust sb else to pack me a 3m ball screw from China.
  1. Welding 5-8mm steel box-section tubes
    By techcobweb in forum Welding, Brazing & Equipment
    Last Post: 17-07-2018, 05:53 PM
  2. Welding bench
    By Boyan Silyavski in forum Metalwork Project Showcase
    Last Post: 12-07-2015, 05:01 PM
  3. RFQ: RFQ TIG welding
    By Robin Hewitt in forum Projects, Jobs & Requests
    Last Post: 01-02-2013, 10:41 PM
  4. Welding Consumables
    By GTJim in forum Welding, Brazing & Equipment
    Last Post: 13-12-2012, 01:33 PM
  5. TIG welding
    By Robin Hewitt in forum Welding, Brazing & Equipment
    Last Post: 03-04-2012, 10:38 PM
