Thread: Linear rail question
04-02-2016 #11
Hello again all you CNC-jedi!
Jazz, still have no computer at home, the frame question has to wait. But here is another!
Ive read that Ali extrusion isnt flat enough to mount rails to (but Ive seen many builders do so) What do you think about machining a flat steel strip maybe 30-40mm wide, 4-6mm think and mount this between the rails and extrusion? Just drill through and use a longer bolt for the rails? Or would I just get the same imperfektion in the steel when I thighten the bolts?
Has anyone use this chinese type of rails?http://m.aliexpress.com/item/32446258288.html
Autocorrect om a phone is a bitch when not using your own language ;)
Best Linear rail mounting set up
By j2sip in forum Rails, Guideways & BearingsReplies: 5Last Post: 19-07-2014, 12:00 AM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
