Thread: Linear rail question
24-03-2017 #31
Jazz you are a genius ;)
I'm happy I asked!
How about my other question?
Will 4 nema23 4amp motors from cnc4you drive my 60kg gantry when using the machine vertical? :D I assume 1 motor each for y and z is okey and 2 for x (standing axis)
Like I wrote I will be using 80v digital drIves with 68V psu...
Have a nice weekend
24-03-2017 #32
Yes they will be ok. My machine uses same size motors with similair weight gantry. However I have put counter balance on the gantry to stop it dropping when motors are un-powered.
The motors handle the weight perfectly fine without counter balance and it's just there to stop gantry falling when unpowered. However it does assist the motors meaning can run slightly higher rapid feeds than when counter balance isn't used.
If you park the gantry on end stops each time motors powererd down then wouldn't need counter balance but the way I use my machine means often power down motors through out the day but control is left on so don't want the hassle of parking each time.
26-03-2017 #33
Thank you! Then maybe I should think about implementing some weights.. Hmm. . ;)
26-03-2017 #34
No I'd suggest just allowing for possiblty of needing them but try without first. My other machine which was vertical didn't need them but had slightly lighter gantry. Also I'm talking about the gantry traveling up/down not side to side so if your traveling side to side then no worries at all.
24-06-2017 #35
Okay! New question :D
How do you guys do when painting the steel parts?
The frame will get painted up to the epoxy strip. That's easy! And rhe gantry is extrusion au naturale. But all the different parts of my Z axis are milled flat. If I paint before mounting rails or carriages I might get problems?
If I paint with everything attached and mask the rails of there may be ugly gaps if I have to move/adjust something?
What to do?
/Mad
Best Linear rail mounting set up
By j2sip in forum Rails, Guideways & BearingsReplies: 5Last Post: 19-07-2014, 12:00 AM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
