Thread: Linear rail question
19-07-2016 #15
Really you want to keep the x axis (gantry assembly?) as close to the bed as you can.
I can't remember what I went with on mine but I think I left around 150mm clearance from the lowest part to the bed, this will be reduced though because like you I'll have a bed plate, sacrificial plate and so on.
My machine was originally aimed at sheet work, in wood, so that's what I had in mind at the time, though I didn't know as much then as I do now and a few things changed along the way.
So again keep it as low as you can but do consider if at some point you may want to add an additional rotary 4th axis to the bed, the size of a chuck for instance would need to be accounted for, you may just need to lay a chuck on the bed as a clamp or for use in an indexing operation.
.MeLast edited by Lee Roberts; 19-07-2016 at 01:39 PM.
Best Linear rail mounting set up
By j2sip in forum Rails, Guideways & BearingsReplies: 5Last Post: 19-07-2014, 12:00 AM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
