    I have been reading alot! Hiwin hgr20 seems to be everyones choice. Ive read that 15 is to small.. Is this purely in hight or is it width aswell? How about the egr series?
    Or even better for the wallet, chinese hiwin copies.. How do those match upp?
    Been looking at iko and thk aswell but they seem to have alot of series with only two ballraces and i guess that this inte ideal?
    Regards
    Madman
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Regards
    Madman
    There is not much price difference between 15mm and 20mm the trouble with 15 mm is it can be very tight in the z axis unless a lot of material is milled away. The Chinese stuff is fine you can buy it all at the same place including screws and bearings etc this is one place BST http://es.aliexpress.com/store/314742
    I've got 15mm on my Y & Z and if I was doing it again I'd buy 20mm all round. The Z axis I've got round by using a 40mm thick plate and recessing it for the ballscrew and mounts so I could put the bearing carriages flat on the back plate...
ID:	15967Click image for larger version.
    Neil...
    Build log...here
    That pic explains the problem very well. ..Clive
    Hello again!
    I understand the problem, but why doesnt ppl just use 25mm rail and thinner ballscrew?
    If you use 1204 ballscrews with bk/bf10 you would get 3mm extra for ballnut clearence and just have to make a bracket?
    Or am I missing something vital? :D
    Hello again!
    There are many ways to do the same thing but your way is adding expense and weight to an area where you want to limit the moving mass. The larger rails don't really add much strength but they are considerably more heavy.
    Maching slots for clearence while trouble some if not kitted up to mill the slots does give the advantage of reducing weight without sacrificing too much strength. The lighter and shallower 20mm setup gives a very strong and low profile setup making for a nice balanced Z axis.
    Either way would work.! Thou IMO the 20mm rails with lighter plate setup gives better balance of strength and acceleration/speed with nema23 motors.
  1. Best Linear rail mounting set up
    By j2sip in forum Rails, Guideways & Bearings
    Last Post: 19-07-2014, 12:00 AM
  2. Open Rail, open source linear rail?
    By Musht in forum Open Source Designs & Plans
    Last Post: 15-06-2012, 12:21 PM
  3. WANTED: Where can I get some 8 - 10mm linear bearings - rail
    By alanb in forum Items Wanted
    Last Post: 21-07-2010, 07:10 PM
  4. FOR SALE: Linear rail and bearing
    By black5f in forum Items For Sale
    Last Post: 02-07-2010, 07:23 PM
  5. Supported linear rail question.
    By IN-WondeR in forum Rails, Guideways & Bearings
    Last Post: 05-02-2010, 12:25 PM
