Thread: Linear rail question
Hello again!
I understand the problem, but why doesnt ppl just use 25mm rail and thinner ballscrew?
If you use 1204 ballscrews with bk/bf10 you would get 3mm extra for ballnut clearence and just have to make a bracket?
Or am I missing something vital? :D
09-09-2015 #2
There are many ways to do the same thing but your way is adding expense and weight to an area where you want to limit the moving mass. The larger rails don't really add much strength but they are considerably more heavy.
Maching slots for clearence while trouble some if not kitted up to mill the slots does give the advantage of reducing weight without sacrificing too much strength. The lighter and shallower 20mm setup gives a very strong and low profile setup making for a nice balanced Z axis.
Either way would work.! Thou IMO the 20mm rails with lighter plate setup gives better balance of strength and acceleration/speed with nema23 motors.
Best Linear rail mounting set up
By j2sip in forum Rails, Guideways & BearingsReplies: 5Last Post: 19-07-2014, 12:00 AM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
