Thread: Linear rail question
Depends on what precision your looking for.? If mostly cutting woods, plastics etc with the occasional bit of aluminium profiling etc then Aluminium profile is perfectly fine.
There are a few things you need to take into account thou. Rail width and slot size need to be matched. For instance I wouldn't use 10mm slot with 15mm rails as this can cause problems due to profile slot having rounded edges. You need plenty of rail each side of the slot.
I use lots of profile with 8 & 10 slots but always with 20mm rails and don't have any problems.
Best Linear rail mounting set up
By j2sip in forum Rails, Guideways & BearingsReplies: 5Last Post: 19-07-2014, 12:00 AM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
