Thread: Linear rail question
Aah that sounds much better! As I mentioned earlier I will route mostly hardwood. Oak for the most part!
I will go the "standard" way with raised x-rails from the steel frame. Epoxy leveled. Then use a 160x80 Ali profile with 8mm slots for the gantry.
Im going to have the gantrysides watercut from 10mm steel, or is it better with 20mm Ali?
The Z plate will be 20mm Ali but Im thinking about using 10mm steel for the y-car sounds good?
Grinding howls
The Madman
Skickat från min D6603 via Tapatalk
Best Linear rail mounting set up
By j2sip in forum Rails, Guideways & BearingsReplies: 5Last Post: 19-07-2014, 12:00 AM -
Open Rail, open source linear rail?
By Musht in forum Open Source Designs & PlansReplies: 0Last Post: 15-06-2012, 12:21 PM -
WANTED: Where can I get some 8 - 10mm linear bearings - rail
By alanb in forum Items WantedReplies: 4Last Post: 21-07-2010, 07:10 PM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
Supported linear rail question.
By IN-WondeR in forum Rails, Guideways & BearingsReplies: 20Last Post: 05-02-2010, 12:25 PM
