    I don't see how copper would be easier than plastic. Copper should be done in steps with annealing in between, that shape i mean.
    Plastic could be heated/ gas torch/ , pressed over shape and rapidly cooled in cold water. Then next...
    I had a go with some copper pipe. It does work and will form to the shape without splitting, no need for heating. Copper pipe for plumbing comes in 'half hard' or 'full hard' spec and the 'half hard' stuff is suitable for bending and flaring. - https://www.youtube.com/watch?v=3e103_ULgpI
    However... it took a LOT more pressure than I expected. I pressed a mandrel into the 28mm pipe using a bearing puller and even that found it tough. I had hoped to rig up a big lever to press it, but no way would it be strong enough. Okay I could build a machine to do it, but I'd probably spend longer making the machine than simply getting on with the plastic ones. So I'll go with plastic.
    Sven's Avatar
    Lives in a, Netherlands. Last Activity: 07-05-2020 Has been a member for 9-10 years. Has a total post count of 46. Received thanks 4 times, giving thanks to others 0 times.
    I think that copper will only be as quick as pvc if it can be shaped in one stage.
    And then it will still need some fancy tooling.
    Doing it in pvc would only need simple tooling, a few for shaping and some holding device to place the ends in to be heated at only the area that needs to be formed.
  1. Replies: 0
    Last Post: 24-03-2015, 05:04 PM
  2. RFQ: Machine Design and build for PVC pipe
    By D-man in forum Projects, Jobs & Requests
    Last Post: 20-07-2014, 06:10 PM
  3. cutting and engraving sheet alu and copper with cnc router
    By chris in forum Metalwork Discussion
    Last Post: 21-02-2014, 10:55 AM
  4. expanding foam and steel frame
    By Gytis in forum Metalwork Discussion
    Last Post: 18-08-2013, 10:35 AM
  5. Pipe thread in 22 tpi???
    By Robin Hewitt in forum Machine Discussion
    Last Post: 21-09-2010, 11:19 AM
