Thread: Expanding Copper Pipe?
I had a go with some copper pipe. It does work and will form to the shape without splitting, no need for heating. Copper pipe for plumbing comes in 'half hard' or 'full hard' spec and the 'half hard' stuff is suitable for bending and flaring. - https://www.youtube.com/watch?v=3e103_ULgpI
However... it took a LOT more pressure than I expected. I pressed a mandrel into the 28mm pipe using a bearing puller and even that found it tough. I had hoped to rig up a big lever to press it, but no way would it be strong enough. Okay I could build a machine to do it, but I'd probably spend longer making the machine than simply getting on with the plastic ones. So I'll go with plastic.Last edited by Tenson; 21-08-2015 at 11:34 PM.
22-08-2015 #2
I think that copper will only be as quick as pvc if it can be shaped in one stage.
And then it will still need some fancy tooling.
Doing it in pvc would only need simple tooling, a few for shaping and some holding device to place the ends in to be heated at only the area that needs to be formed.
Babits, a successful Hungarian CNC manufacturer expanding into the UK
By Babits in forum Manufacturer NewsReplies: 0Last Post: 24-03-2015, 05:04 PM -
RFQ: Machine Design and build for PVC pipe
By D-man in forum Projects, Jobs & RequestsReplies: 0Last Post: 20-07-2014, 06:10 PM -
cutting and engraving sheet alu and copper with cnc router
By chris in forum Metalwork DiscussionReplies: 2Last Post: 21-02-2014, 10:55 AM -
expanding foam and steel frame
By Gytis in forum Metalwork DiscussionReplies: 11Last Post: 18-08-2013, 10:35 AM -
Pipe thread in 22 tpi???
By Robin Hewitt in forum Machine DiscussionReplies: 3Last Post: 21-09-2010, 11:19 AM
